Parking Brake
The parking brake in my Denali goes to the floor, and doesn't really do much. I recently did rear pads too, but never even looked at the parking shoes. is there an adjustment? or do I tighten the cable like the old fashion cars?
You need to pull the rear rotors to adjust. Very common if they are toast at this point as well. Mine were toast within 10K but since the upgraded kit, I'm still on the second set of shoes 150K later. Pull the rtor and cive the star a few clicks and try to fit the rotor again. THe manual states to measure the drum and show to get it right. I just tighten it until I can barely get the rotor to spin by hand.
