SNOW!!!!!!!!!!!!!
busta
They say we might be getting a little snow here in northern KS and I say bring it on. First winter w/ the new truck and new BF Goodrich AT KO tires. Anyone have any experience with these tires in the snow??
I had them on my ZR-2 and they were awesome in the snow, felt like no pile of snow was too deep to drive through. I wish I had them now but can't bring myself to replace brand new tires on my truck.
Ya those tires are sick I had them on my '94 burban and just got a set put on my '00 longbox Z. It's been snowing here all morning and now changing to freezing rain. I am just jonesin to get out and drive home now!!! :cool:
G
I ran those tires on a 1977 1/2 ton 4x4, 3.73's carb running rich and fast, Heavy throttle-happy driver, and a three speed on the floor. I had to try hard to bust 'em loose in 4-hi. Them tires are a poor man's Blizzak. Up here in Wisconsin, it's about all you'll see. Tried and true, good choice.
I'm in KC and they were calling for 2-5 in. but we only got a trace of heavy wet snow. I've had the KO's on my truck for about 3 years now and have been great in the snow and rain. :banghead:
I've been praying for snow here in Indy.
I'm on the airport snow team and [sNOW] = [$] so, bring it!!
Here's my choice in snow removal equipment (Oshkosh Rock's):
Never really checked the tires, but I think they're BFG's.
We rarely get enough snow to justify this bad boy, but for $240K we couldn't pass it up. :banghead:
We rarely get enough snow to justify this bad boy, but for $240K we couldn't pass it up.  :D
:crackup::D:eek: Holy crap that is one mean machine. I beet it doesn't take long to clear off a runway with that bad boy. :banghead:
:D  :eek:  :D Holy crap that is one mean machine.  I beet it doesn't take long to clear off a runway with that bad boy.  :crackup:
Bout 15 minutes w/ the plows, then 15 to 20 minutes with the blower, then another 20 with the plows for cleanup. So for a 11,200ft. runway it's bout an hour.
That is if nobody stops to pee! :banghead:
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
