Trnny problem...
With the gear selector in D and doing 45-50 mph i will be locked in OD. If i gently increase throttle i can hear the engine (?) clinking, like it is lugging! The tranny wont immediately downshift unless i give it more throttle, and then the ping stops. I know if i drive in 3 i dont have this issue.
What's goin' on? Is it the tune? I have increased line pressure to 35% and upped shift point 200 rpm only.
Your converter clutch locks in at around that speed, making it first a release of the clutch, then a downshift to third, a double step. When the clutch is locked like that at a low rpm it is not uncommon to get a slight ping because the engine is really lugging. In third the revs are higher and the engine isn't lugging.
  • 3 weeks later...
