Brake Noise
We got some Ice on the roads today, and my Brakes started making noise, I was driving slow for a long time, and they did put something on the roads. so I was thinking this was why??
I've only got 22k on her 04 Silverado LS ECSB I shouldn't have to replace the front pads "already?"
