ALLISON RUNS GREAT BUT ( BLEADING )
02denalilvr
I HAVE A 03 HD WITH 6.6 WITH ALLISON TRANSMISSION. THE PROBLEM IS THAT I HAVE A LEAK IN THE TRANNY AND THERE ARE TWO DEALERSHIPS IN THE AREA THAT SAY THEY CANNOT WORK ON IT. IS THIS A BIG JOB OR WHAT IS THE DEAL. WHAT CAN I EXPECT FROM THIS TO BE THE PROPER FIX OR WHAT DO YOU KNOW OF THIS PROBLEM. ANY THOUGHTS OR RECOMMENDATIONS WILL BE GREATLY APPRECIATED. THEY SAY THE PROBLEM IS FROM THE BOLTS THAT CONNECT THE TORQUE CONVERTER AND THE FLY WHEEL. THANK YOU
I don't understand why they say they can't work on it. Don't they repair transmissions? If they're a Chevy dealership, they should be qualified to work on it and have the necessary special tools.
We have never had to pull an Allison out for any reason and haven't had any that leaked. Pretty solid trans if you ask me. I can't tell you what's wrong. Obviously you're going to have to find someone that will work on it.
Yea I thought that was pretty crazy that they couldn't work on it. I am loosing confidence in these dealerships. I will have to go about 30 miles to the nearest one that may be able to work on it. If I can't find anyone around here, I will probably try getting in touch with GM and see what they recommend. thanks for your help.
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 496 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
