4WD Problem
2001-2500HD
Its a 2001 2500HD with 1 8.1L & Allison. It has the floor shifter, not the push button 4wd.
When I put it in 4-hi, the transfer case engages but the axels dont lock in...4-lo works fine. The 4wd light does not come on when in 4-hi and it does when in 4-lo.
Any ideas ?
Thanks, Artie
Sounds like the front axle actuator has power and is working, otherwise it wouldn't matter whether it was 4HI or 4LO. There's only a single switch in the transfer case to supply a ground to that actuator when you put in 4WD. Not sure why it would work in 4LO but not 4HI.
I know...I thought it was weird...I even put a new actuator on it and no dice... Any way I can get a wiring diagram for the actuator ? Is there a way to hot wire it or put my own switch on it ?
Thanks, Artie
    2022LtTbZ71
    2022LtTbZ71
  • Who's Online   2 Members, 0 Anonymous, 984 Guests (See full list)
