Best for pulling 5th wheel?
Recently I was looking at a large 5th wheel trailer and the salesman suggested I would need a 1 ton DRW to pull it. DRW is pretty much out of the question as I don't want to deal with that much truck for daily driving. I then looked the max trailer weight numbers up on chevy.com and got pretty confused!
VORTEC 8100 V8 WITH AUTOMATIC TRANSMISSION
2500HD 2WD Extended Cab with 8 foot bed - max trailer weight 15,700
3500 SRW 2WD Extended Cab/8 foot bed - max trailer weight 15,500
3500 DRW 2WD Extended Cab/8 foot bed - max trailer weight 15,300
The price of the trucks I got from carsdirect.com.
2006 Chevrolet Silverado 2500HD 4x2 Extended Cab 8 ft. box 157.5 in. WB LT3 Target Price: $31,631
2006 Chevrolet Silverado 3500 4x2 Extended Cab 157.5 in. WB SRW LT3 Target Price: $31,823
2006 Chevrolet Silverado 3500 4x2 Extended Cab 157.5 in. WB DRW LT3 Target Price: $32,136
2006 Chevrolet Silverado 3500 LT3 w/Duramax 6600 HO Turbo Diesel Engine 4x2 Extended Cab 157.5 in. WB SRW Target Price: $36,968
5K difference for gas vs diesel? This would be for a truck that would pull a 5th wheel 4 times a year totaling 8K miles. I was surprised at the difference between SRW and DRW. Only $313??? Also, the 2500HD and 3500 SRW numbers are almost the same. I guess the 3500 would be the best? What would DRW do for me other than cost more money when it is time for new tires?
How large is the fifth wheel that you are looking at, what is the empty weight, GVWR and Pin weight? The main difference between the 2500HD the 3500 SRW and the 3500DRW is the GVWR of the vehicle, not the towing capacity. The 2500HD can tow a lot but can't handle as much pin weight as the other 2, where the 3500 DRW can handle much more pin weight but you said that a DRW is out of the question. So, to answer your question we will need to know more about the fifth wheel you are looking at.
I don't have the GVWR for the trailer the salesman showed me but here is the info on a 5th wheel I like that I found online.
Dry Weight 11600lbs (5262 kg)
GVWR 16000lbs (7257 kg)
Cargo Capacity 4400lbs (1996 kg)
Hitch Weight 2450lbs (1111 kg)
The reason for the few hundred pound difference between the SRW and the dually is accounting for the weight of the extra two rear wheels/tires/larger fenders, etc. The GCWR (towing capacity)is the same between a 3500 SRW and a 3500 Dually. The dually has a higher GVWR (payload capacity).
The actual towing capacity is determined by taking the GCWR and subtracting the actual weight of the truck + passengers+cargo inside the cab/bed.
If the truck is going to be a tow vehivle only, I'd definately go with the dually. The dually is a lot more stable especially with a 5th wheel travel trailer. If its going to be a daily driver as well, I'd possibly consider a SRW, but I'd suggest a dually for a few days to see how you like it. It really isn't that much harder to manuever a dually around parking lots etc.
hope that helps! :D
hope that helps!  :D
I just have to find a dually I can test drive for a few days.... There is a local dealer with a brand new 2004 diesel 3500 DRW on the lot. It would be interesting to see what kind of deal he would make on it.
The maximum trailer ratings posted are very deceptive. As Silverado3500 said all the trucks you listed have the same GCVW of 22000lbs. (if they all have 410 rearends)This is the maximum weight of the vehicle/cargo/pasangers/trailer/any load in the trailer. The rating posted are for an empty truck with one driver. Every passanger you add is less you can tow, any cargo is less to tow.
A duelly will be a lot more stable on the road.
I have had 2 Fords and now a Chevy... The Chevy tows much better than the Fords... I tow a 10k 5th wheel and I dont have any problem with fish tailing... The dually was created to stop fish tailing when towing a standard trailer... 5th wheels usually wont fish tail regardless... My big problem lately is oil consumption..
Not trying to come across as rude or anything, but duallys were not created to prevent fishtailing. The point of the dually is that the 2 extra wheels/tires (tires mainly) can handle more direct weight (payload in the bed). The tires are the weak link in the weight handling capacity of a truck. The added stability is just an extra benefit that having the wider wheelbase of a dually offers. Like you said, a 5th wheel/goosneck trailer typically should have very little fishtailing (trailer sway) issues.
Say for example that a certain load range E tire can handle 3,000, to 3,500 pounds. On a SRW that effectively limits the weight rating on the rear axle to 6,000-7,000 lbs. On, a dually with 4 tires instead of two, the weight capacity that the axle can handle, nearly doubles. (I say nearly because when tires are used in a DRW application, they are typically rated slightly less.)
Trailer-sway is mainly a bumper pull issue, and the longer bumper pull trailers without an anti-sway bar can make for "white knuckle" driving even on a dually. I can vouch for this personally. The cause of this is having the pivot point behind the rear axle. When the truck turns, the trailer goes the opposite way just briefly before following the truck. On a 5th wheel/goosneck the pivot point is directly above or just forward of the rear axle, eliminating the opposing motion.
Again, if I came across as rude, I apologize, as it is not meant to be. Just trying to help. :)
Hey I could not have said it better myself.... Everything you say is valid... Especially with the Tire Load Ratings... Its just I did not want to write that much....Im just lazy... Sorry...
    520Zilla
    520Zilla
  • Who's Online   4 Members, 0 Anonymous, 545 Guests (See full list)
    • Hi all,   I just bought a 2021 suburban RST with 88,000 miles on it and everything has been good but I’ve been noticing within the last month or so that there are small electrical things going on and I know what the AGM batteries and all the electric electrical in these big trucks you need to have a constant flow with good voltage   That being said, I bought a new battery thinking that that might have something to do with it but today I went to get in and start it and it said no key found when I had the key right in my pocket   It also proceeded to flash the lights inside and outside for over 30 minutes as I went to disconnect the battery as soon as I touch the negative terminal, I heard the relay reset and everything come back up. I got in the truck and started it no problem.   Anyone else have this happen to them? I’m starting to think it’s the KARR system that the dealer installed short circuit stuff.
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
