my truck just died
gadget
hi guys,
i have a '96 C2500 Silverado, with about 140k.
i had just filled my truck up with gas (girlfriend almost ran it dry, farther than i have ever gone down) and i was driving about 50mph, then the engine just shut off. i pulled over to the side of the road and tried to start it again but it just wont turn over at all. the starter will turn over the engine like normal, but it seems like it is not getting any gas. i thought maybe it was a sensor of some sort, but when i hooked up the OBDII scanner nothing came up. i have already replaced the fuel pump about two years ago. i need some advice.
thanks guys, mike.
A failed fuel pump will not show up in a scan of the computer. So, you could have another dead pump or you got a tankload of crap when you filled up. Those would be my guesses.
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 605 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
