hard to start
donwp
2001 4.8 hard to start when engine is cold have to put your foot on the foot petal for 1 to 2 minutes and then the engine will run fine then it will restart and run fine
That's kinda confusing. You have to put the pedal down for 1-2 minutes before it will start or is that to keep it running after it starts?
yes to keep it running after it starts?
it will starts and die
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 230 Guests (See full list)
