looking at an 06 sierra. got ???
i pretty much have my mind set on the 06 1500 extended cab 4x4. the thing i dont know about is which motor to go with, the 4800 or the 5300. is that power that much different? what about the mpg? i dont do any towing really but do like power. is the 5300 that much worse in the gas mileage area? any other options i should look at or stay away from?
remember if you get a 1500 4x4 Ext.Cab Standard Box with the Z71 on it you can get the 5300H.O. and that motor is a beast
I have it in my 06 and i chew up my friends hemi in it.
It is really leaps and bounds better than the iron block 5.3
Get the bigger motor. The bigger motor will get the same (or even better with a load) mileage, resale will be higher, and when you need it, you've got it.
You can justify going with the 4.8 liter if you select the LS model. They also come with basic equipment, such as cruise, tilt, power windows and locks, and content theft alarm. And are priced about $ 3K less than a base LT1 model. You cannot get the Z71 package with the LS model. But if you are looking for the best value for your dollar, the LS version is the way to go.
Just about all LT models will come with a 5.3 liter, because dealers (practically without exception) order the light duty power package on these trucks. This consists of the 5.3 engine, trailer tow package, and locking rear differential.
I looked at hundreds of new '06 4X4 pickups on the gm.com website, and I did not find any LT truck with the 4.8 liter engine.
No. Most of 5.3 engines on '06 trucks are still cast iron blocks. The aluminum block 5.3 is designeated as "High Output" version, , but the horsepower difference is pretty small - only about 20 HP more.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
