1995 5.7 GMC Suburban
Just finished a new motor install and have replaced the cam shaft with a Comp Cams camshaft, lifters and springs. I zero'd the lash then went an additional 3/4 turn.
At idle everything is nice a quiet but run it up to 2500 rpm and I can detect what I think is some rocker arm noise. The old motor didn't have this noise so I'm fairly convinced I haven't got the valve lash set exactly right.
Is there a break in period where I should expect a little extra noise or?? I'm going to call Comp Cams too but I wanted to post it here and see what input I would get.
Thanks,
SG
Manual say zero lash then 3/4 turn.
Comp Cams instructions say zero lash then 1/2 turn.
Comp Cams help desk says zero lash and then between 1/4 to 3/4 turn.
They went on to say that due to the lobe ramp that this cam will generate a slight "sewing machine" sound, which is exactly what I am hearing. I've re-adjusted the valve lash twice with the same result so I'm convinced that this is the way it's going to be. Any thoughts?
SG
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 805 Guests (See full list)
