Clunky shift from 1 - 2
Kalgorn
I've got the M5 in my truck with the 4.3L and it has a really clunky shift from 1 - 2. I ruled out it being me because I've tried pushing the clutch in quickly, slowly, etc and it still does it.
The sound doesn't really bother me but I just want to make sure there's nothing wrong with it. It only has like 210 miles on it.
I'm guessing that at 210 miles, there's nothing wrong and you're just not accustomed to the vehicle. Take it back if you're unsure and let 'em check it out.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 230 Guests (See full list)
