89 4.3l running rich
89 4.3l TBI
Just had the motor rebuilt(bored 060 over). The motor is now running really rich. Rich enough that the plugs are wet and a dark brown in color(repalced plugs and wires same result). Replaced the injectors recently no help. Base timing properly set to 0*. Fuel pressure @ 12.5(spec 9-13). Vacuum check shows 21-20 in. bounces to indicate rich running engine. Once warm idles horrible but drives ok. Did a run on winaldl and it verifies rich. Should I be looking at a spark or sensor problem? Anyone willing to take a look at the data and offer any advice would be appreciated.
Also I have not yet set the minimum idle air. Should I replace anything before doing that? If I give the engine a vacuum leak it will lean out nicely(obviously).
http://nodial.net/onthego/20060111_173024_LOG.xls
PROM ID 3491
Thanks,
MArk
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
