2001 GMC SIERRA 2500HD REAREND
I BOUGHT THIS TRUCK USED ABOUT A YEAR AGO-- WAS TOLD IT HAD A LIMITED SLIP REAR END-- I DIDN'T THINK IT WAS WORKING-- I WENT TO SERVICE IT AND FOUND IT WAS NOT LIMITED SLIP-- I VERIFIED IT WITH THE RPO CODE-- I WOULD LIKE TO LOOK INTO AN AFTERMARKET LOCKER BUT DON'T KNOW THE EXACT MODEL OF THE AXLE-- IS THERE A STANDARD THEY USE ON THE 2500HD?? IS IT THE SAME AS THE 3500??
THANKS FOR ANY HELP!
Go to http://www.americanaxle.com
There is full info on the complete GM rear end info. there.
GMpowertrain.com also has full info.
Pretty sure that GM uses the same axle on all 1500/2500/3500 trucks.
Prob. except for dualies...............
There are aftermarket limited slip/posi etc. units out there.
..........................geo
Someone correct me but I think the 1500 and 2500 use a 9.5 (?)semi floating rear
The HD uses a 10.5 (?) full float and the 3500 (with D-max or 8.1) uses a 11.5" full float.
Not sure, but last time I checked the 2500HDs that had the 8.1 or Duramax have the 11.5" ring gear too but that might just be the newer models like 04 and 05. From what four wheeler magazine says, there is no locker for an 11.5" ring gear after market, well last article I read, but one should be developed, if not already.
:confused:
rob :D
:cheers:
rob :fume:
my '01/8.1 has the 10.5" ring gear w/ 4:1 RP ratio. ARB makes an air locker for the rear and that's on my 'next to get' list. Have ARB selectable lockers on the Jeep and is the best hands down, IMO.
mb
If you have the 6.0, you have a 10.5 ring gear. . .with the duramax, it should always be an 11.5. The 8.1 depends on whether you have the allison auto, or the 6 speed, and the axle ratio.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
