Fram Oil Filter Alert !!!
I have posted this before on other sites, figured I might as well save a few engines on this site as well. Check out the oil filter study here:
http://minimopar.knizefamily.net/oilfilterstudy.html
How about this email from a Allied Signal Production engineer(can be found on the same site posted above)
Russell,
I obtained great satisfaction from reading your oil filter survey.
I worked for two years as the oil-filter production line engineer in
an Allied-Signal FRAM facility and I can confirm every bad thing you
have said about FRAM automotive filters. That's from the horse's
mouth, as it were.
I'm also a quality engineer and can confirm that FRAM applies no
quality control whatsoever to any of the characteristics for which we
buy oil filters. I frequently saw filter designs which were barely
capable of meeting J806. Many of FRAM's designs will block and go to
bypass after trying to filter very little contamination. There were
often leakage paths at the paper end discs when these were not
properly centered on the elements. Some designs had the pleats so
tightly packed against the center tube that they would block off in no
time. I had discovered that the FRAM HP1 that I had been buying for
about $20 Cdn was EXACTLY the same as a PH8 inside - the only
difference being a heavier can - no advantages in flow capacity. The
paper filtration media was of apparently poor quality and the process
of curing the paper resin was very inconsistent - elements would range
from visibly burnt to white. FRAM's marketers admitted that there was
just about no way the public could ever prove that an oil filter
contributed, or did not prevent, engine damage. The only thing FRAM
tested for was can burst strength. Another problem that they have from
time to time is in threading the filter base - often there are strands
of metal left behind on a poorly formed thread. :D
I have not used a FRAM filter since I started working there. Their
claims are entirely and completely marketing bull****.
If people really want to protect their engines, a good air filter is
vital (which excludes FRAM from that list as well) and a combination
of one depth and one full-flow hydraulic filter, together in parallel,
will do the job of filtration to perfection.
Thanks for doing a great job in trying to get the truth out! You can
quote me anytime. "
You guys better think twice about running their crap on your rides. :confused:
I've never used any FRAM filter at all and I'm glad I haven't!!!! :D
Nothing but AC-Delco filters for me (Except for a K&N air filter) :confused:
Yea,You do have to watch where they were made at,All the ones we get in here at the dealership are made in the USA so I'm OK there.
Several months ago I purchased two Fram oil filters from Wal-Mart for my GMC trucks 04 Yukon and 05 GMC Z-71 I noticed that the oil in the Yukon was going down, checking under the truck found that the Fram was leaking, replaced with A/C and now no leak. So I can attest that Fram oil filters have problems.
These sorts of 'preferrable' filters or whatever other product is being compared is very subjective.............Ive used Fram in all my vehicles for the last 20yrs and never had a problem with the filters or problems due to the filter...........maybe I've been lucky.........or maybe they aren't so bad..............sure there might be better filters but that doesn't mean Fram is a god awefull filter.......just my 2 cents worth...... :D
I have heard all these storys before but ,I have a 1995 chevy pick-up with 295,000 miles on it that would say otherwise.Always used fram and never touch the motor. Just my story :D
You guys are saying Fram is low a quality and you use K&N air filter? K&N is near the bottom of the barrel.  Yes it flows well but it dosent filter well which is why it flows well.  Do a search online about airfilter comparison. WIX ranks top quality on air and oil filters.
Check out this site
http://www.bobistheoilguy.com/airfilter/airtest1.htm
And it is for these reasons that I do not use any K&N filters. As you said, they flow well, but do not filter that well.
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 473 Guests (See full list)
