Bose Premium Amp questions....
I am finally starting the process of putting the center console in my truck. I really want to use the sub located inside the console. I am tring to do this with as little more cost as possible. Since my truck has the stock 4 speaker system... what are my options...
Can I get a line converter and use that to feed the input of the amp??? Looking at the wiring diagrams the pin outs of the radios are the same except trucks with the amp have "low-level" outputs (same pin I assume the radios just output a lower level signal). I notice the amp has an input for class 2 serial data...What does this line do....
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 304 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
