Anti lock brake re-call
Anyone brought their truck in for the recall? What did they do, replace sensors or clean or say nothing was needed. Did you notice anything different after?
What recall?
What recall?
If you didn't get the recall letter then I guess your truck is not involved.
I brought mine in yesterday. I cleaned the mating surface about 1 1/2 years ago and my ABS was fine until about 3 weeks ago. Since there was a recall, I figured I would let them do it.
All they did was clean them the same way I did. I drove off the lot and my ABS was kicking in every time I touched the brake at slow speed. I turned around and brought it back in. The tech said he was very sorry and fixed it again, this time he replaced the ABS sensors. He said he had tested them and they seemed to check out fine but he replaced them and the problem went away.
3 hours and no charge, new sensors, I'm good with that. :cheers:
That was what I was worried about, making them worse. I will bring mine in Tuesday, hope they just swap the sensors out.
What recall?
Well if your the original owner staying at the same place when you brought it you may recieve it. Could you at least give us what make and year?
Thanks
What recall?
Thanks
The recal was for specific NBS year trucks.......im not exactly sure which years but I know my 2000 was one of the years that was recalled..............my truck has the ABS problem bad........they activate everytime at low speeds.........I had to pull my ABS fuse it was soo bad...............so i took it into the dealer.........they checked my VIV and apparently GM is only recalling certain years and certain VIN's.................now that is F#%&^ pathetic..............so I have the right year that was recalled.............I have all the symptoms..............but for some reason my VIN doesn't qualify....
I had mine repaired prior to the recall notice coming out. It was really bad. They actually replaced both hubs on the front (ABS sesors are inside). It cost me a lot of money in the beginning, however I qualified for the reimbursement when the GM recall came out. So I submitted all of my repair info & they did in fact approve the reimbursement! I was paid in full for the cost(s). So if need be I would suspect you could have the complete hubs replaced?!!
I don't remember which years were involved, I think it was 2000-2003. The kicker is the truck had to have been purchased in the "salt belt states" where GM determined there was enough snow/ice that the use of salt on the roads was probable. Problem is, if you bought your truck in California and moved to Maine, you would not be in the recall. :cheers:
I don't remember which years were involved, I think it was 2000-2003. The kicker is the truck had to have been purchased in the "salt belt states" where GM determined there was enough snow/ice that the use of salt on the roads was probable. Problem is, if you bought your truck in California and moved to Maine, you would not be in the recall. :D
Pretty pathetic of GM don't you think?...........hell if the vehicle has the problem then it should qualify..............I guess it will take someone getting in a real bad accident because of the ABS problem and sueing GM before they do the right thing and recall all vehicles based on the year the problem exists in not where the truck was bought...... :mad:
I had mine repaired a couple months ago...they tested the sensors, and replaced them. I never really had a problem...but I guess the sensors were bad. :D
Amen.
THey did the same crap with the sorry parking brake(only recalled the manual tranny ones).
No wonder they lost 8 billion$ last year, if you dont take care of your customers somebody else will :D
Amen.
No wonder they lost 8 billion$ last year, if you dont take care of your customers somebody else will :mad:
This bit about GM not wanting to fix my ABS got to me real bad this past week..........so I emailed GM, and explained to them that my truck is the right model year, and has the ABS symptons, and and I am not accepting their B.S answer of 'they are only doing certain VIN'......I told them in the email that if I get into an accident because of the faulty ABS, then I will be suing GM...........not evern an our passes by and GM calls me and tells me to take my truck to the dealer and if the dealer says its the ABS problem, then GM will pay for it.......so im off to the dealer tomorrow..... :D
Amen.
This bit about GM not wanting to fix my ABS got to me real bad this past week..........so I emailed GM, and explained to them that my truck is the right model year, and has the ABS symptons, and and I am not accepting their B.S answer of 'they are only doing certain VIN'......I told them in the email that if I get into an accident because of the faulty ABS, then I will be suing GM...........not evern an our passes by and GM calls me and tells me to take my truck to the dealer and if the dealer says its the ABS problem, then GM will pay for it.......so im off to the dealer tomorrow..... :banghead:
Who at GM did you send that to can you provide an address?
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 348 Guests (See full list)
