Leveling System question
I just recieved my new Performance Products Catalog. They have an add for a leveling system by Ready Lift, it gives you new keys and shock extentions. Says it retains factory ride and installs in 30 min. Anyone try this system ?
its $229 for a 2000 to 06 Chevy truck or burb
Scott
Scott
Do you have any pics of the parts?......also, I would be concerned about the angle of the CV shafts.......sounds like this leveling kit is going to really lift the front end up........just assuming this because it comes with shock extensions...... :banghead:
I've seen a similar kit (the one I saw actually had longer shocks) and that's exactly what it does- lift the front end. As far as CV shaft angles go, this is not much different than cranking the torsion bars. I haven't heard any feedback from anyone about this type of kit yet, but I can't imagine it being worse than cranking the torsion bars alone, except in the hit to the wallet. :banghead:
All this Kit does it life the frt about 1 1/2 inches to let the truck sit level. My Burn sags in the frt . I have no pics but it just contains new keys for torsion bars and shock extentions.
you can check it out at www.performanceproducts4trucks.com
Scott
Although Offroad Unlimited says their kits won't harm your drivetrain, I'm still concerned about the CV joints. I really don't know the actual degree of angle, but adding another 1-1/2" of height is a lot of angle. I max'd out my bars once on my '05 EC Z-71 and road around town for a week with no problems. The first time I got on the interstate and hit about 65 MPH, it sounded like the front end was going to fly apart. I went back home and dropped the front end about 1/2" and the noise went away. It could have just been a fluke.
Mine are cranked up about 1.25" and no problems here. Factory shocks also. No notible noises neither. I'd consider putting that kit on mine when I need to put shocks all the way around on mine.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
