Pioneer AVIC-D1
Will a Pioneer AVIC-D1 fit ina 2006 Silverado without mods?  Is it a painfull install?
Thanks,
Mack
Upon my recent installation I was wondering how one of those would work in my 02. I discovered that the problem would come in to play with the automatic tranny in park, and trying to eject the screen. I believe it would bump into the gear shift every time.
And, if memory serves me right, the GM dash opening for the radio is 1 1/2 DIN, and this radio appears to be a double DIN. Not sure of the 2006 models have a larger opening or not, so, might take some googling on your part.
That AVIC-D1 looks to be a really sweet system, though.
  • 1 month later...
Thanks,
Mack
I have one in my 2006 Tahoe and it fits fine.
I have an older Pioneer 6500DVD in dash in my 95, and as was said don't try moving the gear selector until the screen moves up into position.
I have the Eclipse AVN5435 in my 06 and it looks almost factory. Doesnt hit the shift in park or in gear. It is much better made than the Pioneer AVIC Series I would look into this unit before purchasing the Pioneer... IMO
  • 4 weeks later...
Any pics of installed unit?
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 453 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
