GMC died while driving
my 2001 yukon xl died about 3 blocks from my house, i was able to coast home so at least its in my driveway (barely)
engine just died while driving, gas gauge says dead empty but I know it had about 1/2 tank yesterday. just put 5 more gallons in and it still says empty and will not start.
battery is good and cranks fine....when cranking gets oil pressure etc but gas gauge says empty. was thinking fuel pump but why would that effect the gas gauge? unless they are on the same circuit somehow.
so do I call AAA or is there an easy fix?
yup, I believe pump and sender are one assembly. I find the gages really inaccurate. They stay on full for a long time then rapidly drop to 1/4 then seem not to move for the longest time. Every GM truck I had was this way. I've resorted to using the trip meter. I can consistently go for 650km and have 6 litres left in the tank.
On my 97, it changes constantly. Sometimes it will read full, others 3/4, and down to a half. I just go buy the mileage as well.
I never tow, but I do have the bigger 5.7l and an extended cab. Most of my driving is done on the freeway going to and from my welding classes. I'd say I get about 15-16 mpg freeway.
I'd go ahead and replace the fuel sending unit, fuel pressure regulator, and fuel filter. :dupe: If you can afford to. I've been having fuel guage problems on my truck since 70,000 miles, one of these days, the fuel sending unit is getting replaced.
Since your pump and gauge failed at the same time, it is unlikely that both would quit together. You most likely have a simple wiring problem where these two circuits share a common point. Probably the ground wire for the tank assembly. My bet is you have no problems with either the pump or sender. It is wiring. Don't throw money at any problem, I always run out of money before problems. You gotta find out exactly what is broken.
Ken
Mine died Sunday with a bad fuel pump,had it hauled to Chevy for a total bill of $729.33 , a screwing with no kiss...AND THEY BROKE MY DOOR HANDLE AND GIVE IT TO ME,without fixing it I WAS HOT...$237 labor,$441.57 Pump,$9.48 misc.,$41.28 tax.......here's a good site ,factory parts for 1/2 price
http://www.gmpartsdirect.com/
$441.00 for a fuel pump??? :jester:
If all your fuses are good, I'd say it's likely to be a problem with the sending unit &/or fuel pump. Try listening closely (to gas tank) for the fuel pump to come on when the key is turned to the on position. It should kick on for a second & give you a good smooth humming motor noise from the tank. If it doesn't come on after a few turns of the key or it comes on & doesn't sound smooth (grinding noise) then your pump is probably gone.
I also believe that your sending unit & pump are interconnected by the wiring in the tank. So if your sending unit is shorted/fried then it could cause the fuel pump to not function.
I freakin hate the electirc fuel pumps....maybe we should go back to mechanical!!!!!! :jester:
$441 and 57 cents, boy did I get took to the cleaners,I can deal with the labor but for the pump good grief, that's why I hate the dealer..........been there before and they tryed taking me for things that were OK, I fix what I can, I heard finding a good mechanic is like finding a good Dr..............I can believe that!!!!
Guest chevydeerhunter
That's why it's called a stealership!
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
