Head Gasket
I have a 1995 GMC Sonoma with a 2.2L MFI 4cyl engine. It keeps leaking coolant and blowing the head gasket, 3 times in 3 years at $1500 a pop from the stealer :banghead: . What is the real problem? Warped head? Shouldn't the stealer notify me of this and mill the head?
Thanks in advance!
:cheers:
Thanks in advance!
:cheers:
They haven't milled the head? Has it been checked? Have the head bolts been changed everytime the head was pulled? Those are the questions I'd be asking.
If it were me I wouln't have taken it back 3 time unless the job was done under warranty and on the 2nd time I would have been on their azz.
The dealer won't tell volunteer to tell you squat. You need to ask very pointeed questions and look over your bill from past repairs and see what was replaced and go from there. That will tell you alot.
  • 3 weeks later...
  • 1 month later...
Ive got the same motor. I blew my gasket last winter at 158,000 miles. Luckily I work at an auto parts store and got all my gaskets,new belt,Head milled & pressure tested and misc... all for 140.00 Lowest quote I could get from the local mechanics was 700 so I made out like a bandit. Since then shes been runnin great.You should try next time ya get it fixed to put some BLOCK SEAL in there. The head isnt a solid piece of metal its actually molded like styrofoam with little tiny metal pelets and some times theres hair line holes in there. At least thats what was explained to me.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
