4.3 Running Rich / Hesitation Probs
This is quite frustrating, any help is very much appreciated. Problem is with a 97' 1500 with 4.3 vortec. Standard cab, long bed, 2WD, VIN 'W' truck.
Basically, truck runs and starts just fine when cold. As soon as it gets nice and warm to operating temp, it develops a hesitation and sometimes WILL NOT shift into it's last gear. Thus causing very bad fuel economy and keeping me from driving on the highway.
I've read a lot about the fuel injection system on these trucks acting up. First time I took it in to the mechanic, and $500 later he found a faulty fuel pressure regulator that was throwing a stream of fuel straight into a cylinder.
This time around the problem has developed again. It is obviously misfiring at idle (rough idle, truck shakes a little), and power / fuel economy have gone down when warmed up. A plug check revealed the rear two cylinder plugs showing a very dark, carboned tip. The rest of the plug tips were clean (AC Delco platinum) with light colored ceramic, but a somewhat dark base at the end of the threaded part.
I am about to dive into it myself this time, as I am pretty mechanically inclined and have had it apart before. I just need to know some obvious things to look for.
I know to check the injectors and make sure they are spraying, not streaming. I know to also make sure no fuel is coming out of the pressure regulator. My questions are this:
Are there other obvious parts to check that could be causing a rich condition when warmed up other than the injection system? Such as regulators, sensors (maybe O2?), valves, ect... Why would this cause the truck to NOT shift into it's last gear when it's running rough? What are the chances the pressure regulator (AC Delco part) failed again?
I don't mind replacing parts myself, I just need to know what to replace. With another $500 mechanic fee saved, I can replace quite a bit myself. I was about to just pick up an entire spider assembly on Ebay (genuine AC Delco) for the $300, but figured I'd stop by here to see what the experts had to say.
Again, PLEEEEASE help! I really appreciate any advice you can give me. Thanks!
    Bulldogger
    Bulldogger
  • Who's Online   5 Members, 0 Anonymous, 737 Guests (See full list)
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way to big should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crosing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
    • And overpriced. I was in the Oshawa Truck Plant when they were being built. Very few. I could count on one hand how many I've seen since
