Changed dash lights?
Changing the bulbs is easy, changing the color is a little more difficult, for instance one bulb may illuminate a white section of the dash, like hvac area and also illuminate the color, like the temperature. It can be done though, I even thought about doing it but was reluctant to try it for "proper" illumination purposes. Also if you are changing the color there are a lot of bulbs that need replaced. Several in the radio, several in the HVAC, several in the power window/lock switches, several in the instrument cluster, T-Case switch if applicable, Head light switch, air bag switch... That's if you want them to match, which I would.
    Kirk Belch
    Kirk Belch
  • Who's Online   4 Members, 1 Anonymous, 962 Guests (See full list)
