Body Lift guys
What size rubber are you running on the stock rim?
Have you moddified your nerf bars to cover up the frame???
Thanks
I cut I think 1" off the Block for the Nerfs and it looked SWEET on my old 2000. It also made the truck look higher. I ran 295/75 on stock (The narrower tire looked TINY), then I upgraded to 305/70's and they looked smooth, but a 315/75 with a t-bar crank and a 3" rear lift block, was the sweet spot!!!!! The 6" Suspension Lift and 37" SSR on 10" wheels was the sweetest.
are those tire sizes on stock wheels?
what brand did you choose?
The 295/75r16's were BFG AT KO on stock
Then came the 305/70r16 Goodyear Wrangler AT/S on Stock (Tread was cooler on on BFG's, but the 305's width made the truck look better)
Later the 315/75r16 Procomp AT's were fitted on stock, then to 16x10 KMC Tanks.
