AVERAGE GAS MILEAGE
20 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
97 GMC 5.7 3.42 rear. Stock as GM made it (except for the stainless steel manley valves) Did a valve job at 85K because the heads leaked oil at the drainback holes in the head.Truck has 105K on it. I just recently changed the FPR and fuel pump as it wouldn't hold pressure in the rail.
99 3/4 ton stock except 2006 3/4 ton aluminum wheels. 22 pounds a piece lighter than stock steal may make a slight difference in mileage and performance.
4.10 gears
265/75R16 tires
5.7 engine
  • 4 weeks later...
I have the old TBI, but I did have a topper on with about 2 and 1/2 sheets of 3/4" 4x8 sheets of plywood with 2x6's and tools so the weight is similar to a burban. 3.73's 265/75/16's and over 200k and I get around 11-12 mostly city. Worst tank ever was 4.4mpg and best was 18.1mpg.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
