Newbie
Hessian
Hello everyone. I haven't had a GM truck since my '88 GMC 4x4 with a 350 EFI. Loved it. Since then I see, there are some new engines. First do they still make the 350? If not, can anyone direct me to a place that shows the history of the new engines, I am mainly interested in the V8's. I am looking to buy a used truck and need to know what was available say since 1998 until now. I also see on the Chevy site engines referred to 4800 and 5300, can someone translate this into cubes or even liters? Thank you all for your help.
Craig
Craig
4800 = 4.8l = 295cu in
5300 = 5.3l = 325 cu in
Thank you pwall for the info. They must have quit making the 350. Do you know when they stopped the production of the 350? What is your opinion of the 5.3L in the full size truck? Thanks again.
They had the 350 in pickups up until 1999 (but only in the old "Classic Style" in 1999).
1988-1995, 350 with throttle body injection (two injectors).
1996-1999, 350 with multiport fuel injection, Vortec heads, different intake manifold, etc. with mass airflow sensor, about 250hp.
The new style Silverado (1999) had the new designed engines, 4.8, 5.3 and 6.0. The 6.0 was available in the 3/4 ton and up, and still is, with the exception of the 2006 models (called the "Vortec Max") and the Silverado SS.
The 5.3 had about 285hp up until 2004 or 2005 and was increased to 295. The 2006 5.3 high output has 310hp, and the 4.8 now has 285hp.
Thank you tflessner. That is the information I was looking for. I always liked the 350, but I would imagine the newer engines are better. I will at least know what I am looking at while I search for a truck. Thank you again. Take care,
Craig
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
