Correct tranny performance
vgodenwa
Hi,
I installed an aftermarket Superchip program on my 2001 Silverado 2500 4X4 not long after it was purchased and everything was fine - loved it.
When I replaced the tires with 245 to 265 height increase, the truck was a little down on power, and the Superchip has the ability to compensate, so I reprogrammed using the "book" tire height from the manufacturer. The truck felt much better, but I noticed the tranny unlocked the torque converter at the slightest lifting of the gas pedal, which it didn't do before. So I started backing down .25" at a time and the condition improved.
The problem/question is this: I can't now remember what the tranny felt like at stock tire height. :chevy:
At highway speed, say 65 mph and about 2000 rpm (3.73 gears), should the converter immediately unlock upon the gas pedal lifting, or should it hesitate at this rpm. I would prefer it to stay locked, but I don't want to lose the performance improvement.
Part of the problem is that the book says the tires are 31.76", but on the truck, they only measure 30.25". I may have overcompensated.
Anyone who has a stock truck, notice for me how/when the converter unlocks if you would since the GM Tech is out of action.
Thanks Von Odenwald
It should release as soon as you let up on the throttle. I have very little experience on aftermarket "stuff" but OEM is a different story. The tire size should be programed into the EBCM. I do not know if your programmer does that. Offhand I would say say that you do not have a problem. By the way, cool first name.
Thanks,
I think it is more noticeable due to the louder muffler I installed at the same time as the tires.
That is part of what is making it hard to remember - didn't sound the same.
Von
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 206 Guests (See full list)
