'99 Trailer Wiring
Suburban K1500 with factory traler wiring, including the brake control and 12V. Need to know where the "other" end of the brake controller wire is, as I will need to install a brake controller. Seems that for the newer trucks, there is a connector/pig-tail that is used, but not for the '99 Sub.
Thanks
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
