2005 brake pads
Does any body know if the front brake pads changed for 2005 on a 2wh dr ext cab gmc Sierra 1500 ( not heavy duty) when they changed the rotor size?
Thanks and have a great day. :cheers:
Don
It depends on what brake option you have.
I can give you the part number but I need your VIN number to give you correct one or you can look inside your glovebox and give me the "J" codes,There are three different sets,Look for either "JF7" "JC4" "JH1" or "JH6" (JC4 and JH1 take the same part number)
I believe the RPO code is JF7. The aftermarket suppliers say the pads did not change. I just want to be sure before I order some expensive pads. I can give you the vin later.
Thanks Don
Thanks Don
OK the VIN is 2GTEC19T251320951. Thanks so much for your help.
I used to work for a Pontiac, Buick, GMC dealer in Gallatin Tn. It was destroyed by a tornado last Friday. The good thing was no body got hurt.
Thanks,
Don
Hey Don,
Your right,The brake code is JF7 on your truck,The GM part number for the front pads is 89059119,But according to what I'm showing they are new for '05.
By the way,I'm glad no one was hurt last Friday,I heard about the wicked weather that came through there,Are they planning on rebuilding the dealership?
Rich. :seeya:
Hey Don,
        Rich. :seeya:
Thanks for the information. Yes I believe they are going to rebuild. I was by there this morning. It is a total loss. Also the tornado only missed me by a couple hundred yards. It took out half of my street.
Don
The 05 1500's got larger rotors and calipers, so I would assume that it also got larger pads to fit the larger calipers.
I know the feeling, a tornado missed my house by only a few streets in 2003. Glad to hear you and the truck are ok :seeya:
Hey Don,
        Rich. :D
Don
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
