05 Silverado Question?
SilveradoLAX7
I have an '05 Silverado with about 13,000 mi on it. As long as I've had it (nine months / 7,000 mi) I've had a problem with the factory CD player about 1 in every 10 times I use it. For whatever reason when I shut the truck off and turn it on at a later time, no sound comes out of the speakers. I can change tracks, but still no sound. This only happens when playing CDs, not the radio. Power off and on does nothing, the only way to fix it is removing the CD. Its not a major issue but really annoying when a truck basically 'brand new'
Question 1) has anyone else had a similar problem?
Question 2) any quick fixes?
Question 3) is it worth taking to the dealership, or just replacing with an "real" sound system
thanks in advance fellas...
Take it back to the dealer. It just needs a program update. Seen a lot of them.
Subject: CD Player Long Load-to-Play Time, Error Message, CD Does Not Return to Previous Track, CD Does Not Play, CD Does Not Eject, CD Stuck in Player, Radio Will Not Accept CD (Reprogram Radio) #04-08-44-020C - (11/09/2005)
Models: 2004-2005 Buick Rainier
2004-2005 Cadillac Escalade, Escalade ESV, Escalade EXT
2004-2005 Chevrolet Avalanche, Express, Silverado, Suburban, Tahoe, TrailBlazer, TrailBlazer EXT
2004-2005 GMC Envoy, Envoy XL, Envoy XUV, Savana, Sierra, Sierra Denali, Yukon, Yukon Denali, Yukon XL, Yukon XL Denali
2004-2005 HUMMER H2
with CD Player Radio (RPOs UB0 or UB1)
This bulletin is being revised to add 2004 model year. Also, additional conditions and correction information have been provided. Please discard Advance SI Resolution Bulletin Number 04-08-44-020B (Section 08 - Body and Accessories).
Condition
Some customers may comment on one of the following conditions:
• Long CD load-to-play time
• CD ejects with an error message of "CHECK CD"
• CD does not return to previous track after an ignition cycle
• Clock resets to 12:00
• CD does not play
• CD does not eject
• CD stuck in CD player
• Radio will not accept CD
Cause
A software anomaly within the radio has been found.
Correction
If the customer comments that the CD does not eject or the CD is stuck in the CD player, or the radio will not accept the CD, prior to programming the radio, perform the following steps.
Turn off the ignition.
Remove the radio fuse for a minimum of 30 seconds.
Reinstall the fuse, turn on the ignition and the radio.
Attempt to remove the CD by using the eject button or attempt to insert the CD.
If the CD was successfully removed or the radio accepted the CD, then proceed with reprogramming.
If the CD was not successfully removed or the radio did not accept the CD, then the radio must be removed for repair at an authorized Electronic Service Center.
Reprogram the radio with an updated software calibration. This new service calibration was released with TIS satellite data update version 10.0 available October 3, 2005. As always, make sure your Tech 2® is updated with the latest software version. Prior to entering TIS2000, enter the VIN into GM VIS to obtain the RPO codes of the radio and speaker configuration for the vehicle. This will allow for the correct calibration selection. Selecting the incorrect calibration for the vehicle configuration can damage the radio and lead to unnecessary delays in repair time. Once programming is completed, wait at least one minute after key-off to allow the radio to accept the new calibration.
Important: TIS programming supports two calibrations for radios with the UQA amplifier on the S/T models. Prior to selecting the calibration, determine if the amplifier is class 2 or non-class 2. Use the Tech 2® and the following path.
Connect the Tech 2® to the vehicle and power on.
Select "Diagnostics" from the menu.
Build the vehicle from the menu options.
Select "Diagnostic Circuit Check" from the menu.
Select "Class 2 Message Monitor" from the menu.
If the amplifier appears on the class 2 message monitor screen, then the calibration for a class 2 amplifier needs to be selected. If the amplifier does not appear on the screen, then the calibration for a non-class 2 amplifier needs to be selected. Selecting the wrong calibration will result in reduced or no radio volume.
Also, please advise the customer that home-burned CDs must be burned with a "closed session" or the formatting will be incomplete and the player will not read the CD. CDs should NOT have adhesive paper labels affixed to them as the labels may lift off in the player.
  • 11 months later...
I was just searching around for answers to a problem I am having with the CD player in my 2004 Chevy Silverado HD2500. There is currently a CD stuck in the player; when I hit the eject button, I get a clicking sound for a few seconds but nothing else happens. This IS NOT a CD I burned myself or one with a paper label. Could the above mentioned 'software anomaly' be the problem, or does it sound like something else?
I performed the first steps listed in the 'Correction' above (ie I took out the radio fuses, reinstalled, and then tried again to eject), but the same thing happened.
  • 3 months later...
This thread might need to become a "Sticky". The CD player in my '04 just did this this morning.
Player was working fine last night. Got in the truck this morning and no sound coming from the CD. It ejected fine, but while looking for the CD case the radio did it's automatic re-insert function.
Tried ejecting the CD again and it's now stuck in the player. Radio works fine and CD will play. Just won't eject.
Player just clicks and clicks, then displays "Check CD".
I'll try the trouble shooting tips listed above. If that doesn't work, it's off to the dealer.
My cd player ate a cd and never gave it back. I finally brought it into the dealer before my warranty expired. They had me come back the next day when they would have one in stock. Took an hour to install a new one. They called about three weeks later saying my cd had just been returned to them by whoever they sent the old player to for repair.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
