2006 2500HD Trailer Pkg wiring
I am wiring up my tent trailer tonight and got all the wires connected just fine. My problem is the Batt + terminal on the truck connector is not hot at any time. Any ideas to where this leads so I can hook it up? Thanks in advance for your help!
.........From other posts........Inserting a maxi fuse in stud #1 will ... power up the aux. power wire in the trailer/harness/plug.
If you got the factory towing pkg and it's the same as it was a couple of years ago, there should be a fuse taped to the trailer brake controller wiring harness that should have been in the glove box. There should also be an instruction tag of where to insert it in the main fuse box under the hood.
If it's missing, maybe try to get it from the dealer? I can't remember if the owner's manual has information.
You can also search for "stud" or "brake controller" on this site (although beware that there was sometimes some confusion as to what this fuse does).
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
