2000 Silverado not starting
I have a 2000 Silv Z-71 with a 5.3L Vortec. I have not had any problems with the truck, ever. I went to start it yesterday morning, and nothing. Battery is fine, but did not turn over. After about 7-8 tries, it finally started. Has anyone else had this problem, and if so, what was wrong? I'm going to Virginia (Norfolk) next week and if this is going to be an issue, maybe I won't take the truck. That morning was the only time it did that so far. Starter maybe?
Noting as in you hear a click and the motor doesn't turn over, or nothing as in no sounds when you turn the key to 'start'?
Could be either a dead spot in the commutator of the starter, or the soliniod. That is, if your totatlly sure your battery is good.... If you still have the orginal battery after 6 years, it could be getting time for a fresh one.
OK, finally got around to inspecting further and discovered a hole in the starter! Something must have kicked up off of the road and took a small chunk out of it. The hole was about 1/2 inch in diameter. Changed the starter and it is fine. And yes, still original AC Delco battery. Will be replacing that soon. Starter was $141.43 :cheers::D
