Kodiak 5500
Does anyone know a website where I can 'build my own' Kodiak truck? I had this crazy thought the other day to start a small hauling service on the side and wanted to do a little pricing. It's just an idea so I don't really want to go around to all of the dealers for quotes and the Chevy/GMC websites don't offer 'build your own' on the commercial trucks. I'm thinking a 5500 Crew with the Versahauler bed and gooseneck hitch. I'm also not looking for a used one, I'm just brainstorming right now on the cost.
Thanks, that's about what I figured. I know they have a pretty big price range depending on what options, fitment (bed), accessories, trim, etc you get. I'll have to go roaming I guess. I've searched everywhere on the internet and have found nothing in the way of 'build your own' for these trucks.
With that price for a sticker, the dealer is gonna want you sitting right next to him when you write out that check. Go to a dealership and ask..."who can help in one of these 'vetts" and watch how many new "buddys" will be your friend! :bs:
Yeah, you're right about the sales folks. I don't even want to look like I'm interested in ANYTHING around them. If I do this, and that's a huge IF, I'd probably do it with a small-biz loan or something to avoid some of the impulse buying I'm prone to at car dealerships (see truck below :bs: ). That way they don't have to talk me into some crappy interest rate and I'll have the $$$ to dicker a little.
Try the guys over at dieselplace.com, under the tab "any other vehicles". They tend to deal with the heavy of heavy trucks.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
