Installed my RCD lift kit this weekend!!!
Looks d@mn good Tom.  :thumbs:  :) I am jealous, I can't wait to get my truck lifted, soon hopefully, I can't hold out much longer.
now thats what i call a slight difference :thumbs: looks sweet
Looks good Big Bad!  Did you have to remove any of the transfer caseing?  and did you do it yourself?
Did the entire install in 14 hours. Had the help of a friend for about 7 of the 14 hours, but he was more of the "TOOL GETTER" than the hands on guy!
The only "CUTTING" involved was the removal of the upper diif. mounting point on the diff. case, and the removal of the lower rear control arm diff. mount (aprox 1"). By cutting the LCA mount, there is NO NEED to cut any fins off of the Diff!
On a scale of 1 to 10 (with 10 being the best) I would rate this RCD kit 10!
One person can do this themself. Just be sure you have some WHEATIES in the morining to move the front diff. around!
I'm Running the SUPERLIFT BLOCKS in the rear for the added 1.5" of height over the RCD 4" blocks. I was going to run the FORD adjusting keys, but when I put them in I couldn't get the front end low enough!
Everything went together so smooth, it almost seems to easy!
I would do another RCD lift in a heartbeat. The black textured powerdercoated finish is AWESOME!
The kit came with the NEW BILSTEIN zinc/black shocks (no more yellow/blue) and the compression struts are stainless steel! The sway bar extension is machined aluminum. Top notch design!
As you can tell.....I LOVE MY LIFT! It feels like I just went out and bought a new truck!
Everywhere I go I get compliments up the YING/YANG!  Should have done this a long time ago!
    sqidget
    sqidget
  • Who's Online   4 Members, 0 Anonymous, 1,319 Guests (See full list)
