Largest Wheels/Tires
Anybody know the largest wheel/tire combo I can run on the truck in my sig (its 2wd)?  Looking at the 275/55/20 but wondering how big you can go with no lift and no rub.
I am running 275/55/20"s with no problems, you could also run a 285/50/20 and a 295/50/20 without any issues.
I think you could run a 305/50/20 and be ok but it might be close...
I went ahead and got some 285/60/18's.
hmmm was looking at 20"s and ended up with 18"s, why did you move awy from the 20"s?
Good luck with your new wheels and tires :bs:
Mainly because of the choice of tires. Wanted to stick to a LT tire. Also thought that the 285/60 offered the best compromise between handling, looks and ride comfort.
Good luck with your new wheels and tires :P
Understood now lets see some pics of the new set up :mad:
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
