i am a new member and i am looking to make my 2002 S10 into a street machine. i know the 4.3 is one of the biggest V6's on the market and there is no replacement for displacement. i have been looking for parts but not a whole lot has come up. any help would be much appreciated.
hey MATT just put nos on it man , that ill work
:cheers:  :D
Hello, I have just traded off a 1997 Zr2 s10 and have several parts that should work on your truck.
I have a MSD 6al Multi spark ignition box.
the factory wireing adaptor for 97 on Gm (so you dont have to splice)
set of steel power pulleys and a belt for them too.
Airaide throttle body spacer
Hypertech power programmer for 97 gm trucks. (Hypertech will reprogram to any vehical for $200.00)
and a few other parts.
I got allot better throttle responce and about 2 mpg better milage when (if) i didn't get too lead footed. I had 31x10.5x15 tires on it and it would roll them from a dead stop and chirp second with a 3.73 rear end. When I took it all off for the final ride to the dealer it was like a sick pup. Made me sad. My Avalanche does not work with any of thease. I had just got finished putting all of this on, i have all the pacakages and directions. everything is in excellent shape. let me know if you are interested or have any questions. i have had two of the s10s a blazer and the zr2 (both for a while at the same time.) with the 4.3.
Thank you David.
:driving:  :D
Thank you David.
What do ya want for your power programmer?
Cold Air Intake is a fairly cheap but effective way to pick it up if you don't have that yet.
cheaper than a cold air intake and just as good, imo is a drop in k and n and removal of the frotn and left side of the lower air filter housing.
