Service question
Does anyone know what Gm is charging for a filter and fluid change on the Silverados transmissions? I guess I could call but my main question is this--Ive read where the drain bolt is an ass to get off and i was wondering if when i took mine in to get the service , if they would try and loosen it for me or put another one in so i can drain the fliud myself next time.. figured i would let them do a filter change when i take it in for the sensor recall..thanks
well most dealerships put that sucker on with an impact wrench so that they have no chance of having to pay for a motor. but if you get the fron to the truck up on jack stands than you can break that bitch with a breaker bar and alot of elbow grease
If you take it to the dealer for a fluid/filter change they'll just drop the pan the old fashioned way and leave the plug in. It will be just as tight as when you took it in.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
