3.42........... I guess that, with the 360 estimated (flywheel) torque make my 0-60 runs so tough. I was sort of hoping for more 1/4 friendly 3.73. Then I saw code GU6. Yup, first time I checked!
might be wrong, but I though that I heard that there was a trick, if you has 3.42 gears, to do that would make your gears 3.73. Something about the wheels and rear end, although I don't remember. The guy may not have known what he was talking about, but I think he said it worked. Do any of yuou know about this
Guest Friz
Obviously, unless you change the gear, you will always have a 3.42.
If you put a smaller circumference tire on the back, it will make the gear ratio "seem" a little taller. This will pick up your acceleration a bit, but I have no idea how small to go to make a real difference.
I know, but that's why I was so confused, cause I'm pretty sure I was told some trick you could to to readjust the gear for a taller setting
