Parting out '87 GMC 1 ton
I've got a 1987 GMC V-3500. It was a work truck, so it has been used hard on occasion.
454 TBI, TH-400, 14 bolt, single rear wheel, Fisher 8' plow.
I don't know offhand which front axle or transfer case. I'm not sure how to tell, but the axle is either a Dana 44 or 60, and the t-case is probably the NP-205.
Mileage unknown, definitely over 100,000.
The body is rotting, the fuel tank leaks. (It had two tanks, but one has been removed-the switch and valve is still there.)
Truck ran well, got about 7 mpg, which I was told was typical.
It has many new parts on it, but has been sitting, so I'm going to call them newer. ;) Radiator, water pump, front rotors, calipers and pads, P/S pump, Hydroboost unit, cap and rotor, wires and plugs.
The rear weight-referencing proportioning valve still moved.
The bed is in decent shape.
Tires are BFG T/A All Terrain, lots of tread left.
e-mail is yahoo, jscheer509
Truck is located in Bethel, CT right now. (My friend's place-he was going to take the drivetrain, but he's got a Ramcharger now.)
I'd like to arrange things so I can pull the thing apart and get rid of the parts all around the same time.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 634 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
