Changing TB air filter???
Trying to change the air filter on a '02 TB and having some difficulty - removed 2 screws; 1 at the top closest to the windshield and 1 on the right side but can't get the cover to lift off - what am I missing?...or is there some other trick?
Thnaks in advance!!
There are 3 screws holding the airbox cover on. The airbox is on the left side (standing at the front facing the engine) towards the front of the engine....right above the washer fluid tank. The first screw is near the washer fluid filler. The second screw is on the right front of the box near the upper radiator hose. The third screw is on the left front of the box....down between the front cross support, the fender and all kinda hoses or wiring....and its way down there so have a long screwdriver. Then the cover should lift right off. Its a really cool setup...the washer fluid tank serves as the bottom of the airbox. Hope that helps.
