Fuel pump MU1089
I just bought a new Fuel pump MU1089 off ebay for $85 plus shipping. He is asking $100 so I put an offer in at $85 and he took it. He has one left.
Just bought a MU 146 from him for my 1998 1500 Z71. Installed it last night and all is good. Remarkably quiet. I paid $125
[/quote
I bought an MU1089 2 weeks ago and it worked quite well. Went back and bought another so I'd have it down the road.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
