I have a 98 Blazer 4x4 5 speed,the clutch has been dragging for awhile,time to dig into it.The clutch itself seems fine,the pedal is mushy and doesn't release the clutch completely.Of course there may be a problem with the pressure plate or disc.I noticed the hydraulic activated throw out bearing is located internally,like the ones used on Jeeps. Looks like there is no way to bleed the clutch release so that's whay I figure to pull the tranny and deal with whatever is worn.Checking it out,I see no convient way to disconnect the hydraulic hose from the clutch master cylinder from the throwout bearing internal slave cylinder.This vehicle has about 120,000 miles and is the original clutch.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
