Park/Neutral Safety switch Schematic
I need a park neutral switch schematic for a 1998 Z71 with the 5.7L. The gear indicator lights do not work in N, D, or 1, and I think it is the Park neutral switch. However, I changed it out for a new one, and it they still do not work. The truck shifts fine, and otherwise has no problems except for an AC issue that I opened a thread for in a Ask the GM tech post.
I know the indicator lights work, because I removed the gauge cluster to see if I could replace them. As I moved the cluster to remove it, the N indicator light came on (I had the key in the ignition so that I could move the gear shift out of the way). I was able to get each one of the lights to work in this manner. However, I could never get all of them to work at the same time. I cleaned the contacts on the printed board on the back of the gauge cluster, as well as the contacts in the dash. Still no luck. I have of course checked all related fuses, and tested for power. Everything tests out.
The schematic is my last resort, before I take this to the dealer. I hope to be able to test each circuit for a short or bad connection. Any help is appreciated.
