Dash Peeling - Denali
Well, my '02 Denali was attacked by my wife's hand lotion bottle. It sat there for a week and peeled the finish off in 3 1" spots. Any help? Do I have to replace the whole thing or is there a way to repair - It's tan.
Thanks
it's just a vinyl paint i've seen many of them repaired to where they were almost if not completely undetectable repairs, grab the phone book and look for auto interior repair and start calling and if the first one can't fix it odds are he'll know what your talking about it's not that uncommon... ask him who he know that can fix it. there are people who make a good living off of doing dashes and consoles. and a good living at that thanks to gm's fun cost cutting ideas. one dash 10 colors.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
