Wanted: Factory slider rear window
Anyone happen to be stuck with a FACTORY 2006 sliding rear window that they took off their 1500 sierra? MUST BE factory slider as I'm not sure if the aftermarkets looks as sharp. Or....does anyone know if the aftermarket that my local gm dealer would be getting is identical in every detail? Or where can I see one online? the lady at the gm detail shop across the street from the dealer didn't even have a pic of the window she could show me
A salvage yard is probably your best bet for cost and a OEM factory original.
Here's a link from a GM accessories dealer near me. If that's the one you want, give the part number to your local dealer to order it for ya. It's looks the same as mine.
GM Rear slider
  • 5 months later...
