kicker sub and amp combo
i have 2 8" solo-baric L7's in a custom made box along with a 1200.1 kicker amp. i paid $1500 for the complete system so i was thinking around $700 or around there should be the asking price but it is negotiable. it fits in any nbs reg cabs. i dont know how to post pics but are available upon request.
I'd like some pics. email [email protected]
Thanks.
