DVD
7xmoto
I am considering buying a camcorder that records directly to Mini DV's which are the 3" discs. Will they play on my Tahoe's Panasonic DVD player?
Thx
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
