Crank relearn
tmaj1865
can anybody tell how to do a crank relearn, or better yet what does it do??
I have heard people say that you can do it with a scan tool. Is this true??
I'm wanting to buy a new computer from WAIT4ME but I keep hearing about getting the crank relearned. any info will help!
Thanks Mike
A crankshaft variation relearn
must be performed if:
A diagnostic trouble code of P1336 is
present.
The computer has been replaced or
re-programmed.
The crankshaft position sensor has been
replaced.
The engine, harmonic balancer, clutch, or
flywheel have been: disassembled,
removed, or replaced.
The crankshaft position variation
learning feature enables the
computer to compensate for part
manufacturing tolerances. This allows the computer to accurately
detect an engine misfire throughout
the engine RPM range. The learning
process is stored in the computer’s
memory and does not have to be
repeated unless one or more of the
above conditions are present.
Some scanners are capable of doing this. Check local garages.
Anyone with HPtuners or EFI Live tuning software can do this also.
unless you have a buddy that works at a stealer, dont go there, they will charge you the minimum diagnostics fee when the entire relearn procedure only takes about 5 minutes. rip off. not to mention they might not even know what they are doing, i went to both the local chevy and the gmc dealers by me to have this done and both service managers said "we will re-flash your computer and that will take care of it" no thanks, you are not re-flashing my new tuned pcm, i went to a performance shop that had a snap on scan tool, 5 minutes and $15.
so if I'm getting this right, its like setting the timing???? right ,wrong???
I have a Snap-On Vantage diagnostic tool and an OTC Nemisys scan tool.
Niether one will do a crank relearn, as far as I know.
I will have to find someone will a tool to do this.
Does anyone the procedure on how to do this with a scan tool?
Thanks Mike
Thanks Mike
My understanding is it is a diagnostic tool only. It doesn't set the timeing etc. It only is used to determine missfires and which cyl is missfiring. It doesn't effect performance only aids in diagnosing problems.
Anyone with HP tuners EFlive etc can do the proceedure. I believe it is just a button click.
Please correct anything I have said it is what I have gathered from research on this topic. I have no first hand knowledge. I also heard if you don't get a check engine light you don't need it. I didn't get a light and didn't get it done. About a year now with my W4M tune and no problems.
I've done the Westers Tune several times and replaced the crank position sensor. I've never thrown a code. My tech at the dealer told me the relearn wasn't necessary unless you got a code. I'm sure the dealer will do it for you but they'll probably charge you something.
My dealer did it for me because I insisted (after a sensor change) and I know them well. It took about 35 seconds and made no difference in the way the truck ran. No charge.
Bill
Thanks guys for the info. I'm order my computer today, so I'll see what happens. Thanks again for the info. mike
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
