Oil Change
I am comming up on 500 miles on my truck.  I plan on changing the oil at 500,1000,2000, and 5000 miles and then every 5k after that.  I may go to 1000,3000,5000 I haven't decided yet.  I definately plan on an accellerated oil change schedule for the first 5k miles.
I am thinking I will use non-synthetic oil for this accellerated schedule.  I have used Mobil 1 for the past 4 years so I have been out of touch with non-synthetic oil evolution.  What does everyone use and why?
I use Valvoline 5W30 every 3,000 miles. I'm not sure why I chose that oil, but it's what I've used in all my vehicles thus far and I got 167,000 miles out of my Geo before selling it and it was still running strong.
Good luck in your decision
I use Castrol GTX 5W30! I just started using it in my 2001 ZR2 Blazer before I traded it in on the Rado. Although I havent changed the oil in my Rado yet thats what I'll use!  It was on sale once so I got enough for my dads '91 K1500 and it felt like it gave it more power!!!!!!!!!!!!!! Ususally just use cheapest oil we can find in it, so that has kind of hooked me on Castrol!
I use Mobil1 5w30 in the truck and Vette changing at 4-5k. I just put 10w30 Mobil1 in the truck for July and August as it has some heavy hauling to do. I doubt if I would normally go to 10w30 even to drag around a 8,000 lb. skidloader but I had it on hand.
I've always used Pennzoil in my Trans Am's (78 TA6.6, 84 L69, 88 L98).  Since 1989 has been Pennzoil's 100% synthetic 5W50 every 3500 miles.  Last three years has been Pennzoil's 100% synthetic Pennzane 5W30 every 4500 miles.  Past six months adding Fram's X2 filter every 7000 miles.  Of course now with the new Silverado if I were to haul or tow and the oil life was around 2500 miles, it would be changed with filter.
Why Pennzoil...just always used it. So far every vehicle's engine were original, never smoked, never consumed oil.
I probably should have said this in the origional post...
I will be using Mobil 1 at the 5000 and every subsequent oil change.  I just want to use dead dino (non-synthetic) oil to help with the break in.  At $4.84/qt, it would also be very expensive.
Is one non-synthetic generally accepted as better than the others?
Not really IMO! I only use Castrol GTX 5W30 because it is my preference. I do believe different brands are actually different, you can tell this by just looking at it. Such as Havoline looks really dark right outta the bottle, and I used Citgo in the '91 C/K and it was clear, almost white right out of the bottle. Technically you can use anything with the starburst symbol and it meets warranty specifications. This includes the oil that wal-mart sales, which I ma told by the people in the tire&lube dept. that the Super Tech is Pennz-QuakerState. I still dont use it in my Rado but I guess its as good as a pick as any other. It is about a dollar aquart and Pennz-QuakerState is about $1.60 so are you getting better oil or just paying .60 cents a quart more for the name???
MarkD, I don't think you can go wrong with any of the dino oil choices mentioned, as long as the service rating and weight are correct for your application.  I've used Valvoline, Pennzoil, QS, and Mobil dino and never had a problem, although I use Mobil1 now on both my newer vehicles (post break-in) .
IMHO, the oil filter choice is every bit as important, if not more so, than the oil, especially for the break-in period. So don't scrimp on that!  I know the Purolator, AC, and Mobil1 filters all have done well in tests (I'm sure there are others that I didn' mention that are great also) .
My 2 cents.   :)
GreenRado and SilveradoWV,
Thanks, that is kinda what I was thinking.  I only use AC filters (since reading a filter analysis a year or 3 ago).  Occasionally though, I use Mobil 1 filter.  I only use Honda filters on the Accord.
I have the local Advance ordering me some PF59's.
Whats Up with that??? I guess I am going to have to do that too!!!! Wal-Mart and K-Mart did sale AC Filters, now they do not!!! I was hopeing that my local AutoZone would have AC in stock, but if not I will have to get them from the dealer or order them!
I paid $4/filter from Advance for 12 filters.  I decided to go with Castrol 5W-30.  I changed it yesterday to the sounds of "Man, that's good oil, watcha changin it for?"  Because I am A.R. about things like this, ok.
I also got 10 of the 5 qt. NEW synthetic Mobil 1 5W-30 for $17.64 each($3.53/qt).
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,025 Guests (See full list)
