Exhaust Extended Cab 68.5" Box
Trying to see if anyone has put an aftermarket exhaust on a newer chevy with an extended cab and the really short 68.5" box. I have an 06 and no one that I can tell has mad one specific for this truck. The wheel base is 1 inch longer than a standard cab long box so I was thining of trying one of those on for size but I was hopeing someone else had already done the same thing or found one that fit.
Thanks for all your time in advance
well, in my town we have a badass little exhaust shop so i went to them to get a custom exhaust, all weld on. i got true duals tho. i got them to cut the ypipe after the cats and go from there. i got 2 two chamber flowmasters and some 4" stainless steel tips which, holy crap, were expensive. labor was...50 bucks i think and everything else was like 450ish (it's been awhile since i did this). i wanna saw the muffs were 100 a piece and the tips were 50 a piece. so that's 300 right there so 200 for their pipes and labor. hoped this helped at all. probly didn't tho
I had the same issue as you, i also have a 2006 GMC Sierra Extended cab Short Box. my solution was a muffler swap, i went to my own badass little muffler shop and for $150 bucks and about 1 hour they cut out the old HUGE muffler and put in a stanless steel Magnaflow muffler including a custom cut spacer pipe to bridge the gap between the the old and new equipment. they flared the pipes and welded it completely and it sounds amazing. Because as far as i know no one makes a kit for it so i believe custom is your best option.
Good luck, if you want pictures and a video just PM me and i have them.
    mighty K20
    mighty K20
  • Who's Online   4 Members, 0 Anonymous, 564 Guests (See full list)
